Xsara HDi Fuel Gauge
x 1496
Folks,
7 month old Xsara HDI (my Parents' car). Fuel gauge is behaving erratically - it has done this before and been for a replacement sender unit at the dealer. Anybody know how it works, and if it can be cured, or is it a 'design feature'?
Richard
assael1
Unread post by assael1 »
sorry RICHARD ,you cant do anything with tips i wrote. only your dealer can ,with LEXIA diagtool .
Langers
Unread post by Langers »
Got exactly the same problem with my '99 Xsara. Fuel guage is pretty much useless... if you start on a hill, it will not go back to the correct level when you get to a flat section of road. It will continue to display the false reading. As blueboy2001 said, the only way to fix it is to fill the tank up completely.
x 1056
Unread post by wheeler »
check to see if your car needs the fuel gauge configuration update,sometimes it can be corrected by disconecting the battery while the ignition is switched ON,leave for a few minutes then re-connect it again with the ignition still ON.
