electric wnidow
telderv
electric wnidow
Unread post by telderv »
ive just opened the electric window, which worked fine, but then pushed the down button by mistake, the window has come all the way up and now wont open, i can hear/feel the motor working but the window doesnt move
LAGUNA II 1.9DCI DYNAMIQUE
ACTIVE8
x 6
Unread post by ACTIVE8 »
It might help to remove the trim panel, to see what has happened in the door.
ACTIVA
uncle buck
x 10
Unread post by uncle buck »
With the windows in the up position & the ignition on, lift & hold both front window buttons (as if to close the windows) for a count of 5 seconds...this will reset the windows & may sort out your problem.
You sometimes have to do the above if the battery has been disconnected & the drivers side window only goes up an inch or so at a time instead of working in 1 touch mode.
Hope this helps.
Cheers.
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
