Clio Handsfree Kit!
awilson27
Clio Handsfree Kit!
Unread post by awilson27 »
Help! I have recently fitted a handsfree kit to my 52 Clio Dynamique. The Stereo is a TunerList CD and I am unable to find out which connection on the radio will mute the sound when I receive an incoming call.
MAD
Unread post by MAD »
renault supply a kit which just plugs in to existing loom.A bit expensive but saves on looking for wires (takes approx 1/2 hour to connect)
clio_laguna
Unread post by clio_laguna »
have just fitted nokia cark 126 to wife clio and my laguna and both where on pin 3 of th power plug to rear of radio. THen when you ring out or take an incoming call the radio mutes and the disply shows the word speech. Found this by using a 12 volt test lamp and putting it in plug 3 and to earth , which is what the handsfree unit does hope this helps you or anyone else fitting one later
