Ok so my brain has been working overtime on the flickering headlights.
My thoughts are that the hydraulic pump is now electric and will draw a large current on startup BUT that would make the lights dim not go brighter, now when the pump turns and the headlights etc are on the alternator will kick up its output (amps and volts) to cope however when the pump turns off the alternator will take a split second to react and will continue to pump the amps and increased volts making the headlamps go brighter then back.
On the cars that the lights dim it could be the battery is a little weak and cant supply enough power for the pump and headlamps etc hence the lights dim for a split second till the alternator ups it output.
Just my thoughts and welcome any comments or addiotional thoughts.
Rob
Mmmmm been thinking, C5 Headlamp flicker
h2ocooler
2005 Renault Laguna II Sports Tourer Initiale 2.0 Turbo Auto Estate
2003 Citroen C8 2.2Hdi Exclusive Captains Chair
2007 Renault Megane 1.6VVT Cabriolet Coupe Dynamique
02 C5 2.2 Hdi Exclusive Auto Estate (my Dads) DE_FAPPED
Citroenmad
- x 110
Both of our C5s do it, i think they all do?
The fact is the battery is always going to be weaker than the alternator, so there will be a slight flicker when the pump first cuts in?
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
steelcityuk
