Anti-sink valve puzzle
RobL
Unread post by RobL »
Hi all. I've had a bit of a disaster this week - a river of LHM from the front anti-sink valve, the seal has gone on one of the ends. It doesn't look too difficult to repair, however I've spoken to Martin at Pleiades who very kindly sent me a photo of what a replacement should look like - hence the puzzle. There are only 4 pipes coming out of mine whereas there should be 5. Mine has both ends blanked off. He says he can't recall seeing one like it.
Now I could just get it repaired, but I am left wondering that if mine has been repaired/adapted/botched in the past, then where on Earth should the missing pipe go to, since the anti-sink did actually work before, although it had started to sink fairly quickly in the days just before the leak.
Anyone got any thoughts on this?
Btw it's a 99 Xantia 2.0 16v Exclusive Hydractive II
KevMayer
Unread post by KevMayer »
The 5 pipes would normally be:-
1. In - High Pressure feed from Security valve
2. Out - Feed to Hydractive Electrovalve.
3. Out - Feed to Height Corrector.
4. In/Out - Connection to Height Corrector for up/down height control.
5. In/Out - Connection to Hydractive block for up/down height control (through flow from 4).
If you only have 4 pipes then could it be a non hydractive anti sink valve that's fitted and maybe there's no pipe to the front electrovalve? I can't find a pic of a non hydractive anti sink, so, I'm only guessing. Then again, he must have had an anti sink problem as well because it's a much bigger job to change it than just 2 spheres.
It maybe that the previous owner has turned the front end into a non-hydractive version because of electrovalve problems. He'd also have had to fit non hydractive spheres to the front struts.
My Activa had Non Hydractive front spheres on it when I got it. I don't think the front electrovalve was working and the softer speres were fitted to overcome the bouncyness.
Cheers, Kev
RobL
Thanks for that Kev, Ill have another look tomorrow to see if I can identify where the pipes actually go, and to see if there's a stopped off port somewhere where a pipe might go.
I've got it off now, the leaking end simply screws off, it looks like it just needs a new o-ring. This is the end that's supposed to be blank, I can't even see why there's a removable end in the first place - unless there's a six port system out there and this is a standard valve :?:
Regarding the electrovalves - they both work(ed) in that during the timeout both front and back suspension can be bounced, then afterwards both become hard as expected. And just to make it more complicated, I got underneath the back end today and discovered the back valve is the same as the front :?
x 8159
Rob,
There's a bit in this thread about leaky anti-sink valves and the O rings...
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Is it possible one of the pressure lines is "teed" elsewhere? My '99 estate is like that; it has a union that's not there according to Service.Citroen, but is original...
Regards, Adam.
Mandrake
x 694
Unread post by Mandrake »
Hi Guys,
According to the scans I have, there are 3 types of anti-sink valve, but all of them have 5 ports, see below:
http://homepages.igrin.co.nz/simon/imag ... ink-06.jpg
The rest of the anti-sink manual can be found here:
http://homepages.igrin.co.nz/simon/imag ... /antisink/
Hope this helps :D
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
RobL
Thanks for all the replies guys, the resource link from Mandrake was especially useful. I think I may have solved the puzzle :D
According to service.citroen parts drawings, after RP 8280 (ie. my vehicle) there are only 4 ports shown being used, whereas earlier drawings show 5. Mine are 2 to the height corrector, one to the safety valve and one to the front electrovalve/control block.
Now I know how easy it is to remove, I'm going to source a new O-ring, screw it up and give that a go before laying out any more for a new valve.
