Confession time!
I’m thinking of scrapping my ‘98 Series 2 Xantia 2.1TD Exclusive. The cambelt jumped for the second time due to a stripped auxiliary belt when some of the bits of the auxiliary belt got inside the cam cover. Although I subsequently reset the timing and got it going again, its not happy (ok once its running but reluctant to start). I’m sure it needs a new auxiliary belt tensioner to stop it happening again on top of a new cambelt and anything else required to sort out the poor starting. Thinking of having a stripfest over Easter. Will be putting a fair few bits and pieces into stock as my replacement car is a Xantia Hdi Exclusive. However, other bits will be available at very reasonable prices. I am located near Leeds, the car is a Metalic blue hatchback (paint code KPK) and has covered 225k miles.
Rory
Contemplating the Ultimate Sin & Scrapping a Xant Exclus
rory_perrett
vince
- x 13
- x 8263
As much as I hate to see a 2.1TD die, provided it enables others to live then I'm content.. It has had a good life, having clocked up 225K
If you do break it Rory, can I put my name down for the hydractive sphere blocks complete with electrovalves and hydractive ECU please?
Stempy
It's vulture time.
Does it have the winter pack as my headlamp washer pump has packed up again?
Lexia ponce
Lexia ponce
vince
- x 13
Ive checked my paint code, its the same 8)
Id like to come over and see the car if thats ok once you decide to break it. We can then speak about bits and prices....
Im only really interested in the bits i asked about earlier
Brigsygtt
rory_perrett
jgra1
- (Donor 2021)
- x 36
