The passenger side electric mirror has packed up on my Xantia Hdi Exclusive. It doesn't adjust electrically nor does the auto indexing work when you put it into reverse. The driver’s side (which of course doesn’t have auto indexing) adjusts fine. Applying 12v to the connector at the mirror end makes the motors work and it moves. Changing the switch on the driver’s door armrest didn't fix the problem so the next port of call will be to swap the ECU control unit. Question is, does anyone know where this little box of tricks is located? There is a black box on the passenger side door shown in photo 18.3 and 19.7 in chapter 12 of the BOL referred to as the “electric window control unit.” Is that really what it is or is it the mirror controller?
Cheers
Rory
Electric Mirrors Indexing
- x 8458
The mirror index controller is indeed located in the door Rory.
I don't know if this will help but here's a diagram of the indexing mirror fitted to a V6 Auto. It's not 100% applicable but should give the general gist..
Indexing Mirror Circuit
reblack68
- x 1484
rory_perrett
rory_perrett
Electric Mirrors Indexing Problem - now fixed
As Xantia_V6 said, the little black box that Mr Haynes calls a window controller is the mirror controller. Swapped it over with the one out of the other car and everything is working again. Computer fault not a broken wire thank goodness! Really didn't fancy trying to find a broken wire. It must only control the passenger side because the drivers side mirror has worked fine all the time.
mongoose100
Sorry to drag an old thread back up - My V6 has just started playing up with passenger mirror, moves left and right but not up and down with the switch. Driver side fine.
Engaging reverse makes the bloody thing point at the kurb too, really useful when trying to back a trailer!!!
Ideas on where to start?
Regan.
2001 Citroën C5 V6
1994 Citroën Xantia 1.9TD
2001 Citroën C5 V6
