Key Fob
Scottpr
Key Fob
Unread post by Scottpr »
I have just had to replace the battery in my Key Fob.
I believe I have to reprogram the fob after this?
I have tried the only procedure I can find on here (Put key in ignition, turn ignition on, hold Lock key for 5 seconds, remove key from ignition, leave 5 seconds and press lock again) However this didn't work for me, tried it a few times but nothing happens!
Am I doing something wrong?
Is there another way of doing it?
Citroen C5 2.2 HDi Exclusive
Stempy
Unread post by Stempy »
You could try
Hold for 5 secs, press twice, key in holding button and start.
Lexia ponce
Scottpr
Tried that but still nothing happens!?!
Would it need to go to the dealer to get it reprogrammed?
Stempy
You could take it to a dealer but they would probably charge you a minimum of £15. There will be a method but I'm not really clued up on C5's. If you do a bit of searching on the net you may well come up with the answer.
Lexia ponce
x 1056
Unread post by wheeler »
Did it work before replacing the battery ? If so is the battery the right way around ?
Best method is switch the ignition on & keep pressing the lock & unlock buttons alternitively for 10 seconds, remove the key fron the ignition (if you have any other remotes repeat this procedure with them at this point) & shut the door, wait 1 minute & dont open any doors or press the remote during this time, after the 1 minute lock then unlock the drivers door with the key , open the door & close it then try the remote. If this doesent work remove the shunt fuse (marked SH) from the interior fusebox for a few minutes refit it then retry. If that fails then is off to the dealer im afraid.
