STEERING WHEEL RADIO CONTROL
x 94
Unread post by citronut »
dose the wireing from the above go staight to the radio after leaving the plug conector going into the loom, or is it running through the main loom
if so has anyone got the hole thing including the rotory section at the top of ther columb in good condition
regards malcolm
x 94
NUDGE NUDGE BUMP BUMP
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Hi Malcolm, can you look for a radio harness on SC? That would help clear it up.
My gut feeling - based on Xantia II traits, is that the wires would go into, then out of the main dash harness...
Regards, Adam.
andmcit
x 30
Unread post by andmcit »
Malcolm,
If you're not talking airbag steering wheel but the ealier type with just the
radio contols I'm currently breaking a first of the line VSX TD which had
the nicer skinny steering wheel and not an airbag in sight.
It's no problem for me to trace the loom from the centre console and
remove it for you although the steering wheel and the wiring on the hub
are already spoken for...
Andrew
x 94
thanks Andrew
but it do ave an air bag, (no not the missus) and i do/will need the hole lot including the rotary in the steering wheel, unless someone can tell me how to diferentiate between the 5 wires at the loom side of the conector plug just after the steering wheel, as i think there uis 3 brown and 2 green,
the prob i have is on dismatling this the plug brocke up, i tried soldering the wires one at a time, but some of the switch functions do not work now
regards malcolm
Thermonuclear
Unread post by Thermonuclear »
1996 Xantia 1.9 TD
1998 Xantia 1.8 16V
x 94
thanks Thermonuclear
but that looks like just the section inside the steering wheel to the circuit board, the plug and coections im after a breakdown of is were the ribon cable joines the loom in the steering columb shroud, and i think it has 5 wires
regards malcolm
x 94
nudge nudge bump bump
x 94
there must be someone out there who has played around with this wireing
regards malcolm
andmcit
x 30
Just so I'm totally clear what you're after Malcolm; is this the wiring from
the radio to the multi plugs where the steering column meets up or from
that point onto the steering wheel? I seem to recall someone else here
always seems to be after the steering wheel sliding contacts, Toby HDi?
Andrew
x 94
Andrew
what i am after is the hole wireing from and including the rotary ribon cable at the top of the steering columb, which also has a length of ribon cable going into the steering wheel and plugs onto the small circuit board before going onto the wheel switches, then all the way to the radio if possible, or even a diagrham showing which wires are which were they plug together under the ignition switch
regards malcolm
KennyW
x 163
Unread post by KennyW »
Malcolm,
What version of Xantia do you have MK2 or Mk1 :?:
Kenny
C3 1.4 petrol (SWMBO)
x 94
it's a MK1 Kenny which has a recoil canister of ribon cable at the top of the steering columb under the steering wheel
regards malcolm
KennyW
x 163
Malcolm,
I've just managed to knacker by rotation switch and whilst getting one from the scrappie. I just so happened to look at a late Mk1 and it appeared very simialr to my early MK2.
I am wondering if the is a difference between them both.
Kenny
Toby_HDi
x 3
Unread post by Toby_HDi »
andmcit wrote:I seem to recall someone else here
Wasn't me Andrew. Mine work fine :wink:
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
