Saxo steering.
Patt
Saxo steering.
Unread post by Patt »
Hi folks, when I replaced the bellows on the steering rack I tightened up the clamp bolt which connects to the 2 parts of the divided track rod. There was no indication at what angle I should set this to but I reset it to where it was, approximately. No real problem here.
My query is that the track rod "dips" in the middle at this setting and there is no way it could be set level in any case. Therefore when the suspension moves up and down the toe in will alter as it does so and the Haynes bible does not know about all this.
Is this as it should be, can it be changed and what is the best way of setting the track to accomodate this?
The vehicle is a Saxo 1.4 1999.
Thanks for your thoughts.
Patt.
