C5 Fluids
andydykes
C5 Fluids
Unread post by andydykes »
Quick question on C5 fluids for my C5 1.8 LX petrol 2002.
Does the power steering and suspension use the same fluid and is it LHM or something different? I don't have sport mode if it helps.
Current Car C5 1.8LX
Pre Loved Citroen's
Picasso Diesel, Xantia Diesel, Xsara Petrol, BX1.9 GTI Petrol, BX Diesel, GSA, GS
x 5674
Yep, the power steering and suspension share the same reservoire and fluid but the systems are otherwise split and have different pumps.
The fluid is LDS and LHM will kill the system, so I have heard.
Total LDS
andydykes
Thanks Steve,
Is it readily available or do I need to go to the stealer's?
Pre Loved Citroen's
x 8386
Any good factors should stock it. Ours does. I spotted it when I went looking for Esso LT transmission fluid locally, which he didn't have or maybe he did, locked away in a strong-room :roll: I'm not saying it's expensive or anything :lol:
I didn't see how much the LDS was but I don't fancy it was cheap.
I noted that our local factor no longer stocks LHM :o :(
x 5674
andydykes wrote:Thanks Steve,
It is widely available, I have seen but never bought any.
If you have a Total station near you they will likely stock it.
mooseshaver
Unread post by mooseshaver »
I use Comma CHF 11S.
Its the wrong colour (green) but is apparently the right stuff.
The reason I started using it was because I couldn't get any lds when my C5 was leaking.
Gone cars.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
den169
Unread post by den169 »
Mooseshaver are you sure its the right stuff.The comma site doesn't even have citroen on there to use it with.
http://www.commaoil.com/Product%20Pages ... ce/chf.htm
mooseshaver
den169 wrote:Mooseshaver are you sure its the right stuff.The comma site doesn't even have citroen on there to use it with.
The guys at the motor place that sold me it said it was. I've emailed comma now awaiting response.
Did find this though.
http://www.peugeot206cc.co.uk/repair-20 ... eb0mk3.htm
EDIT
and this, less worried now.
http://www.carlube.co.uk/index.cfm?product=134
Gone cars.
den169
Ok should be fine then.
