If you look from front of the car, there is a right angled bracket that comes off the left hand side of the 10mm nut that holds the back of the lhm tank in place. The bracket is parallel with the bulkhead. It has two sensors with 4mm vacuum hose coming off them, that join to a t-piece. The other long pipe off the t-piece goes to nowhere on my engine, what is this for & where does it go? Its been connected up to something it the past as the end is split.
Is this something to do with the actuator pipework, map sensor
Ill try & take a photo tomorrow, access is poor though.
