Dodgy Xantia heater blower fan.
jonathan_dyane
Unread post by jonathan_dyane »
The heater fan on the Xantia in my sig is becoming tempramental, first ocassionally refusing to work, then since the weekend almost always refusing to work. The car has A/C and so the 'climate control' system, which I must confess I have never had anything to do with. The fan even refuses to work on maximum heat and fan setting.
Does this sound like a resistor pack, and if so where is it fitted.
Many thanks,
Jonathan
1986 Mercedes Benz 190D 2.5
1979 GS 1220 Club Estate awaiting more welding
1952 David Brown 30D awaiting new liners
Xaccers
x 186
Unread post by Xaccers »
http://www.frenchcarforum.co.uk/forum/v ... hp?t=24786
Ignotion switch is burning out preventing enough current flowing.
It's an easy fix to install a relay and get your fan working again.
DIY sphere tool
jonathan_dyane
Thanks very much for that Xac, next time the blower fails to operate I shall try the HRW, and if it is inoperative will be carrying out the relay mod.
Regards,
Jonathan
x 94
Unread post by citronut »
mine has a mind of it's own and it is down to one of the conectors with a heavy gauge wire in the 4 pin plug, were it plugs into the fan houseing has got a bad conection and melted the plastic plug body,
i will fix it one day honest
regards malcolm
