stange noise
acelectrical
stange noise
i have two problems with my dispatch 2.0hdi van. the first is that there is a strange noise comming from the engine bay, it makes the van sound like an ambulance, several people have had a look and said bearing, turbo, etc, has anyone had the same problem and got to the bottom of it. My 2nd problem is that today the display disappeared on the mileometer/trip display it did this the other day and came back on, any ideas. 2nd problem now sorted, blown bulb behind milometer.
Nuneatonrob
- x 1056
Re: stange noise, mileometer display fault
There is a little bulb behind the mileometer display, when the bulb goes you cant see the milage & it looks as if the display has gone blank. most likely a bad connection at this bulb.acelectrical wrote:My 2nd problem is that today the display disappeared on the mileometer/trip display it did this the other day and came back on, any ideas.
