Xantia Alloy wheel lock nut key HELP... Anybody a key???
ohms
Unread post by ohms »
Hi all,
As you may remember in an earlier post I didn't have the alloy wheel locknut removal key for my 96 xantia. I still don't, but I do now atleast know which key I need. According to Citroen it is...
GD31
If anybody has one of these pesky things could they have a look at it for me please and see if perhaps they may have the one i need.
Would be really, really appreciated and a massive help
Thanks so much :D
91 Citroen AX 1.4D
99 BMW M Coupe
ACTIVE8
x 6
Unread post by ACTIVE8 »
Is that the one listed, as the one it was sold with?
ACTIVA
ohms
Yep, looks like it. Need to get these stupid wheels off. :)
91 Citroen AX 1.4D
99 BMW M Coupe
x 1438
Unread post by xantia_v6 »
Just checked mine and the numbers and letters are all different, giving the suspicion that there are a lot of combinations.
vince
x 13
Unread post by vince »
potential needle in a haystack? How much are they ordered via Citroen? Cant be more than £20 i wouldnt think..
Or drill the bolt out?
quai_de_javel
Unread post by quai_de_javel »
The new key costs almost same as a new set of bolts with the key. I have asked it in year 2007 from the dealer.
ACTIVE8
x 6
If you contact a main stealer, and find someone who can help there, there might be one person who can help.
Explain the problem, and ask if they can remove the offending bolt using their master set, which should contain all the combinations of all the different ones, used on your car.
This sort of assistance should be free, because they can even get an apprentice to do it for you, and it's good customer P.R.
ACTIVA
ACTIVE8
x 6
quai_de_javel wrote:The new key costs almost same as a new set of bolts with the key. I have asked it in year 2007 from the dealer.
How long did it take for them to get it for you?
ACTIVA
Tavietruffles
Unread post by Tavietruffles »
I bet if you went to your local tyre dealer they would soon get them off for you, i had the same problem on my SL so i got them removed and fitted another set.
I have a few sets of new locking bolts, if you know the length of the ones you require i will have a look
Sorry no Citroens (at the moment!)
Current Cars
2004 Range Rover Vogue
1999 Brabus A Class
1991 Merceded 500SL
quai_de_javel
I didn't buy it. I went to the local tyre dealer and they removed the one that was too hard for the key. Three others I got off myself with the key.
