engine problems?
kang0o
engine problems?
Unread post by kang0o »
Hi i have a 1999 xantia 2.0 HDI. Today the engine sounded very rough and at one point completely cut out but started again. An orange warning light on the dash board appeared, possibly a engine management light on the far left of dash board.
Any ideas? Is this terminal?
'99 Xantia LX estate 2.0HDi Image
Toby_HDi
x 3
Unread post by Toby_HDi »
Is that light still lit? It is the EM light
Any more details on the problem? Did it happen under load? on overrun? at idle?
You say it started again? did it start straight away with no problems? or did it take some cranking or sounded rough?
Is the car now running fine?
The fact the car started again certainly sounds like its not terminal - could be a dickie sensor, hard to say without further details
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
kang0o
Hi, It started straight away but sounded rough. This morning it didn't want to start at all and when it did it sounded like it was running on half a cylinder but did sort of clear after a fews seconds of full throtle, with a massive cloud of blue smoke, but the EM light stayed off.
I put a new fuel filter on but the problem was still there. Really heavy diesel knock at low revs. It also die again, this time on restarting there was an awful noise from the back, think it might be the pump :(.
So might be looking for somewhere to get a good cheap replacement if you can recommend one.
Cheers
nick
Unread post by nick »
kang0o wrote: this time on restarting there was an awful noise from the back, think it might be the pump :(.
Cheers
A noise from the back of the car sounds very like the electric lift pump. Last time I bought one they were about £90 from GSF.
kang0o
I brought some Forte fuel treatment on the advise of my local garage and it has definitely helped. The low rev diesel knock has almost completely gone now. Was still pretty rough when it started though. I do think somethiong maybe on it's way out.
Citroenmad
x 110
Unread post by Citroenmad »
You could als try some forte top end treatment, to reduce noise, oil consumption and help with worn engines. Its worth a shot!
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
andydykes
Unread post by andydykes »
My diesel Xantia had the same sort of problem. Not wishing to be alarmist have you checked the cam belt? Mine had jumped a cog and was running like yours. Shortly afterwards the cambelt went through the cover and caused terminal damage.
I do hope you don't have the same problem.
Current Car C5 1.8LX
Pre Loved Citroen's
Picasso Diesel, Xantia Diesel, Xsara Petrol, BX1.9 GTI Petrol, BX Diesel, GSA, GS
