205 D pump timing
jonnydrumm1967
205 D pump timing
Unread post by jonnydrumm1967 »
Hi, I've just bought a 93 205XLD. The previous owner had advised that the engine was noisy and emitted lots of smoke . He was right! I think the pump timing's 180 deg out as someone's been in about the engine I can see. Not sure for what reason.
Initially changed injectors which made no difference then it dawned on me about the timing. I know these engines will run 180 deg out we had it in the past with a 305 1.9D. Both cars sound similar ie like a Maestro van and loads of smoke.
On the 305 we were changing the pump due to a diesel leak at the nose of the pump,we misplaced the woodruff key and the timing was out.
Do you think I'm on the right track? How do you re-time the pump as it was so long ago with the 305 that I can't be sure now...
Lengthy post...sorry!
Cheers, Jon.
2000 XANTIA HDi 110 SX Est
1992 205 GTI TD
1996 DISCOVERY TDI
2001 XANTIA HDi LX
1991 205 D Turbo
