c5 passengerside wing mirror
oxana
Unread post by oxana »
hi guys
could anyone supply me with the part number for my 2003 c5 3ltr passengerside wing mirror my thermistor is on the blink and due to having arthritis in my hands it would be easily to keep looking on ebay for a new wing mirror and get my mate to fit it
many thanks
ron
ps cant go to my local citroen garage because they ripped me off and if my hands had ive been ok i would have strangled the smug SOB
x 5675
You only need the thermistor, which is around £12, as long as your mate can fit it for you.
oxana
hi steve
my mate is a hammer and chisel man mention electrics and he needs his nappy changing he did have a look and went a whiter shade of pale
imany thanks
ron
x 5675
I'll try and get some more info for you but it is quite simple, the hardest part is getting the glass out intact. There are only two wires to solder.
A decent auto electrician should be able to do it in around twenty minutes. See if you can get a personal recommendation for one who operates in your area.
oxana
thanks steve much appreciated
ron
x 5675
The temperature sender can be changed. You'll need to remove the mirror which has a spring ring holding it in place. Reach it from the outside bottom corner.
'nuther forum
This question comes up fairly frequently.
Somewhere I have seen a very thorough and accurate description of a successfull repair. Can't remember where though.
Those two demonstrate how simple it is. You will need to fix it as it will affect your climate control/aircon.
oxana
hi steve
i have read the the threads on how to change the the thermistor and if my hands wernt knackered i would do it myself but when you are reliant on friends the last thing you want to do is upset them so my mate wants to change the passenger side wing mirror then im afraid its going to be the wing mirror
thanks again for your help
ron
x 5675
I appreciate your problem there oxana. It's a shame he wants to make a mountain out of a molehill but if that's the way it is I guess you just have to live with it.
I had hoped that one of the guys with a "Service Citroen" acount might spot this and help - still might of course.
Why not ring a different main dealer with your VIN and get a quote from them, rather than endure humiliation at your local ignorant pigs hangout? Some of them are both human and helpful.
I haven't had more than fleeting contact with mine - Town Centre Citroen in Sunderland, but was very well treated when I was there and others have reported similar to completely outstanding helpfulness from them.
They may in fact fit a new sensor for a reasonable sum that would be far short of the cost of the replacement mirror.
Where are you - some of the members may be able to recommend a better dealer or specialist.
Alternatively you might be lucky at an independant supplier, like GSF, EuroCarParts or the other one, damned if I can remember the name and the link doesn't appear to be on this computer - I'll be back... :D
oxana
hi steve
many thanks for your advise after a few beers i have persuaded him to try to change the thermistor so next week we are going to gsf in liverpool to get a new thermistor and if he chickens out ive his permission to go to a local auto electrician
again my thanks for your advise
ron :D
