Having stripped and cleaned the front brakes today because the near side front brake has been dragging - much more wear evident on the outside pad here. I have always thought the HB was a bit tight on this car so I have backed the cables off a couple of turns which makes things feel better. I will need to replace the pads and discs soonish, just thinking I might bang in some new HB cables while I've got it on the stands and the brakes apart. 2 questions though:
1. Do I remember right that the LH cable for ML5 boxes is dealer only?
2. What does everyone else adjust them up to? Handbrake on at 2 clicks, or just free play in the cables at the calipers?
Cheers
Richard
ML5 handbrake cables / adjustment
- x 1487
AndersDK
Re: ML5 handbrake cables / adjustment
ONLYRichardW wrote:2. What does everyone else adjust them up to? Handbrake on at 2 clicks, or just free play in the cables at the calipers?
Cheers
Richard
Anders (DK) - '90 BX16Image
Toby_HDi
- x 3
Yes, The n/s is longer but only on the HDi 110, I believe this is not the case with the HDi 90 or anything else fitted with the ML5TRichardW wrote:1. Do I remember right that the LH cable for ML5 boxes is dealer only?
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Previous:
- x 8391
Not quite Toby, the longer N/S cable is used in all vehicles fitted with the ML5 'box, that's the Activa, 2.1TD and possibly the V6 as well. The HDi 90 will use the standard cable as it has a BE3 'box.Toby_HDi wrote:Yes, The n/s is longer but only on the HDi 110, I believe this is not the case with the HDi 90 or anything else fitted with the ML5TRichardW wrote:1. Do I remember right that the LH cable for ML5 boxes is dealer only?
Toby_HDi
- x 3
reblack68
It's longer but it's not dealer only. I got mine from a motor factor. The listings were all wrong in his book so make sure there are two lengths available and you get the longer one.RichardW wrote: 1. Do I remember right that the LH cable for ML5 boxes is dealer only?
Richard
Care of a 1994 205 D.
