LHM tank empty but......
wrinklet1
I have a wierd problem, my LHM tank on my mkII Xantia is alomost empty, but, I canot find a leak or any sign of lhm fluid anywhere. No tell tale marks of fluid leaking, no drip marks, of fluid marks that have been blown when driving. I have moved the car up and down several times to get fluid moving through the system return pipes.
Now I have had 3 Xantia's and 2 Bx's and had leaks on them and there are always tell tale marks.
Any ideas??????
Could it be the cold weather causing the fluid to shrink in any way????
Paul
Any ideas??????
Paul
1xAmi,3xGS,2xBx,2xAX,2xSaxo,1xXantia mk I,2xXantia MkII,1xC1,2xC2,
KP
- x 27
Even with super cold weather it would never shrink that much even from the empty mark.
I would get it topped up and then lower the car and raise it and see if any of the return pipes are leaking or the tank itself maybe?? you would normally see the evidence of a leak though...
Maybe steam clean around the block with teh HP pump and see if its that??
wrinklet1
I agree with what you say KP, but there are no signs at all of any leaks on the car. This has got me baffled. There should be signs of leakage from where ever the leak would be, but nope. Stop light came on o warn me. This is wierd. Couldn't even be a 'bubble' in the system that has been purged because the car has a really smooth ride.......
- x 1484
- x 94
wrinklet1
AndersDK
Nope.wrinklet1 wrote:now thats a point,
I have had a problem with stiff steering in the morning, as in lack of assistance. So, that could be the accum sphere couldnt it?
The acc sphere has nothing to do with the servo assist steering.
The pump has 2 separate high pressure outputs : 1 for suspension and brakes (via regulator & acc sphere), 1 for steering directly.
If the main acc sphere is flat, you should have the dreaded mad ticking from the regulator (sounds as it is the pump) because of the resultant very little hysteresis.
I agree that the mysterious LHM disappearring must be caused by either external leaks or leaking spheres consuming the oil.
Each sphere can hold at least 0.4L, so a couple of tired or flat spheres may soon drink a lot from the reservoir.
However large consuming of LHM is most commonly an external leak.
Try cover the park place under the car with cardboard boxes from your local supermarket.
The green stuff is very easy to recognise from any other dripping.
Anders (DK) - '90 BX16Image
wrinklet1
Underneath the car is clear of any fluid on the floor. I just cant understand it. The rear sphers are new, the ride is smooth and soft as it should be. I bounced the front wings and thay act as they should do.
And your right anders, the steering is on a different circuit.
There isnt a mad ticking either. The inside of the engine bay is dry!!!!
- x 1240
wrinklet1
- x 1240
wrinklet1
DickieG
- Monaco's youngest playboy
- x 38
- x 8321
This is odd. Have a check under the drivers carpet in case the dosuer valve rubber end-cap has split and LHM is leaking unseen under the carpet.
An LHM leak does not always leave a clear trace as it can evaporate. I noted this when looking for the leak on my V6. When running it was dripping but stop and leave it for a day and there would be no trace. This is where parking the car on sheets of cardboard would be valuable as evidence will then be seen.
Is the car a hydractive model? If so, it's worth checking the hydractive electrovalves as these tend to leak only when running (i.e. suspension in soft mode) and can leave very little trace if the leak is noy very severe.
wrinklet1
Ok guys,
Found the leak,
Passenger side rear wheel area dripping lhm. Not sure if it is braking or suspensions piping . It has used about 1ltr of fluid in a day so i think it is the brake hose. it seems to be spraying at the pin end not the sphere end.
Found the leak,
