door noise
col72
door noise
when i open my clio drivers side door i get a loud crack noise i sprayed it with wd40 the bolts are all tight
Onlinemyglaren
- x 5679
col72
Onlinemyglaren
- x 5679
That has been replaced with a nut and bolt. It seems to be the cam inside the door, spring a bit too stron I imagine. Someone has likely had the door of and jiggered it.col72 wrote:306 easy to fix on the door check the side that fits on to the car there is a pin replace that
It isn't a problem, just a bit noisy.
