rear fog lights
x 94
rear fog lights
Unread post by citronut »
N reg XANT 1.9 TD hatch
rear fog lamps dont work, the switch lights up as its spozt to but no power to the rear of car, and a live missing from the relay socket,
previous owner/s have cut open the ruber duckting between the body and tail gate at the O/S, i have pulled the insulatting tape off but no sign of a break in the wire
regards malcolm
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Malc,
I had in a P plate LX car in to sell, with non functioning rear fogs!
It turned out to be a break in the wire between the fuse box and the jining PLUG on the rear a pillar, behind the rear drivers side passenger...
If you remove the trim off the pillar, theres a number of connecting plugs... one of those wires goto the fogs in the boot.. directly from the Fog fuse in the fuse box.. I put in a new wire to the plug and they worked!!!
Rgds
Paul
A very sad...
1994 XM 2.1 d auto
x 94
fixed it today, i finaly traced the fault to being some were in the loom from half way along the O/S/R door sill/ledge (under carpet),to the plug conector on the inside of the rear quarter pillar behind the plastic trim,
this section of loom runs up the front inside of the inner wing under the plastic trim panel beside the seat, there is no obvious way any of the wires could become damaged, but there was no power from the above mentioned section of loom right up to the plug,
weard
regards malcolm
citroenxm
Fallen Hero
x 70
Your Welcome Malcolm!!
EXACTLY what I found!!!
Never mind, at least you got it sorted!!!
Rgds
Paul
A very sad...
1994 XM 2.1 d auto
x 94
thanks for the pointer in the right direction Paul
regards malcolm
