V6 Hydraulic Depressurisation?
x 8391
I will need to depressurise the hydraulics on my V6 in the not too distant.
How do you actually get to the bleed screw to do it? I can just about see the pressure regulator and what looks like the bleed screw but it's up against the gearbox :?
It looks like the airbox needs to come off to gain access but that's currently baffling me too :roll:
This V6 is going to be fun, I can just feel it :lol:
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
You need to get under the car and in effect "Do it from behind" :oops: ooh err!
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
Stempy
Unread post by Stempy »
You can do it from the top but you'll need a long spanner or thin arms.
Lexia ponce
x 8391
Ahh, now I've had the airbox off I can see it well enough but as you say Stempy, a long spanner in the hands of Mr. Tickle is still required!
x 1240
Unread post by Peter.N. »
Hi Jim
I have found that for most jobs, changing spheres for instance, you don't need to depressurise with the screw, setting the suspension to the lowest position will in a few minutes depresurise most of the system - except the centre spheres, the only way I have found ofdepressurising those is a faulty suspension ECU :)
Peter.
x 8391
Peter.N. wrote:except the centre spheres, the only way I have found ofdepressurising those is a faulty suspension ECU :)
Been there, got the green hair to prove it :lol: :lol:
For Hydractive Centre Spheres, a Pleaides tool is your friend :wink:
So how needs a bleed screw... Thanks for the tip Peter :D
