Xantia Vibration
thing
Xantia Vibration
Unread post by thing »
Xantia 1.9TD 1995.
My car start to vibrate when hitting over 100km/h. I have changed both drive shaft, center bearing,engine mounting, lower arm bush. I also have done wheel balancing twice but the vibration still persist.
Anything else that I should look at??
JohnW
Unread post by JohnW »
Did you actually SEE them doing the wheel balance?
One thing that comes to my mind is the possibility of a wheel being buckled and the balance job not able to counteract the wheel not being straight and round. If you watch the wheels spinning on the wheel balance machine (taken off the car, not balanced while on the car) you may get an answer.
Good luck!
JohnW
