Hi.
I have questions to Berlingo owners.
That's my first PSA car. Car was bought in July,2008.
As I understood my dealer, the difficulties during a turning on the gears It's a feature of MA5 gearbox. Does somebody have the similar problems?
May be you have a solution how to solve this problem?
Thank you.
Berlingo M59 (1.4) and it's gearbox
- x 8263
Re: Berlingo M59 (1.4) and it's gearbox
Hi and welcome to the forum
I'm sorry, I don't understand exactly what you mean by this. Normally, the MA gearbox is a very sweet little gearbox that gives very little trouble. Are you experiencing trouble selecting gears?
pk7478 wrote: the difficulties during a turning on the gears It's a feature of MA5 gearbox.
pk7478
Hi Citrojim. Thank you.citrojim wrote:Hi and welcome to the forum
I'll try to explain my trouble
This will be my first technical description in English.
Problem is that during turning on the gear(1st,2nd,3rd,4th), when the clutch pedal is fully down. We hear the crunch in MA-gearbox.
Not always, but crunch presents.
And there's one moment - when clutch pedal down and accelerator pedal is up, i see that turning speed of a crankshaft going down very slowly.
At this moment we're trying to turn on a gear.
Of course, at this moment I hear a crunch. Gears turning on very hard.
Several months ago dealer made update of firmware in ECU(Calculator).
This action helped, but not for a long time - 3 or 4 km.
I replaced a clutch cable - this did not help.
What recommendations can you give to me, where to look and what to do?
- x 94
hi and welome
turnning on the gear= changeing or selectting up or down the gears, crankshaft going down very slowly=RPM revs per minuite dropping,
dose your car have loos mats/carpets, if so first thing to check if the mat/carpet has moved up under the clutch pedel, as this will stop the pedel going to the end of its travel,
next is adjustment on your clutch cable, if so try adjustting that
regards malcolm
regards malcolm
pk7478
pk7478
Here is a service manual for Partner/Berlingo M59 with Diesel and Petrol engines. This book will be very helpful for those, who standing with a
broken car on the road and there's nothing closer than 1000 km.
Please, use it:
http://rapidshare.com/files/194381408/P ... o.pdf.html
Please, use it:
McFuzzi
pk7478
McFuzzi
pk7478
Concerning smoothness of gearchages. Citroen published InfoRapid without any numbers and dates several years ago where you can find
recomendations to replace gear engagement rod for folloowing gearboxes:
Gearbox******Sparepart
MA********************2452 99
BE3*******************2452 A3
BE4*******************2452 A4
My car equipped with MA5 gearbox. After replacement of this rod there wasn't any problems with gearchanging.
McFuzzi
Thanks mate -this is the Haynes manual which I paid for -nice to have it on screen though, in spite that it's probably illegal to share it here... & I don't think it's as informative as it ought to be. The info you supply about the rod replacement is interesting, I will check that out -& perhaps go through the palaver of removing the console so that I can actually get at the clutch pedal...
pk7478
McFuzzi
Hypocrisy? Maybe so -but I think knowledge shouldn't be copyritable -& it's great that people like you are willing to share your experience.
I'm clear that the lack of content in the Haynes book (& often incorrect info) makes the cover price a rip off in the first place anyway! & I'd be the last to wish to give you trouble -I had hoped that the manual you were pointing to would give the visual information about the pedal which Haynes lacks.
