Hi there
Quick question:
The other night I was driving along and thought I'd give the brakes a good test; so I did a few hard braking tests from around 50-60 to a stop. Everything was fine apart from the STOP light came on for a second when almost at a complete stop.
Can anyone shed some light on what might cause this? or is it just normal?
Tom
STOP light coming on during/after hard braking
Xaccers
- x 186
What condition is your accumulator sphere in? How long between it's ticks?
Is your LHM level correct?
Is your coolant level correct?
DIY sphere tool
DIY sphere tool
reblack68
- x 1240
Homer
- x 16
poggle
stop light
mine had been coming on for a couple of days topped coolant up solved that problem got to sort out now where fluid is going
Xaccers
- x 186
Re: stop light
Do you get a wiff of curry when you turn your heater on? If so, the matrix is leaking.poggle wrote:mine had been coming on for a couple of days topped coolant up solved that problem got to sort out now where fluid is going
DIY sphere tool
DIY sphere tool
