My exclusive has heated leather seats but I am unsure if they are actually working. I have checked and cleaned the switch things and they all seem ok and not worn out tracks. Should i really feel it burning my arse? I cant tell if it is getting warm at all as once i sit on it it warms up!
is there a fuse to check? which wiring plug under the seat should i check (not orange!) and is there a way to prove they work (bridge out the switch?)?
any ideas greatfully recieved.
cheers
TIM
Heated seats question - Xantia
xantiatdsx
1986 2CV6 Dolly
1976 AKS 400 Sidewinder
2003 Xsara VTS
http://www.international2cvfriends.com" onclick="window.open(this.href);return false;
2003 Xsara VTS
DickieG
- Monaco's youngest playboy
- x 33
Heated seats are notorious for not working, especially the drivers one, have you tried the passenger seat?
If they are working, on setting three you'll know about it after a few minutes
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
xantiatdsx
oh, ok thanks. might both be dead then. I was sure i had a little bit of heat for a brief time from the drivers but now nothing.
I guess when people kneel on them fetching stuff in and out the car it must damage them really...
anything else to check before i resort to my own heat?!
1986 2CV6 Dolly
2003 Xsara VTS
2003 Xsara VTS
Stempy
The seat and back are separate, my seat bit works but the back bit doesn't. I pulled my seat apart and found that the wires were broken. I made a repair which worked for a while, but it now seems to have gone again, probably broken elsewhere.
Lexia ponce
Lexia ponce
xantiatdsx
hi,
I have checked the 10amp fuse and thats ok (fuse 5) but it refers to that fuse being the fuse for the heated seat relay. Where is this? how can i test it? when putting the seat on wouldnt you expect to hear the relay click? would the current draw be enough to drop the revs or is it a little low?
cheers
TIM
cheers
TIM
1986 2CV6 Dolly
2003 Xsara VTS
2003 Xsara VTS
