2.0 hdi turbo problem
bubber
Unread post by bubber »
Hi all,
This is a 2000 citroen dispatch 2.0 hdi.
Last week the rubber hose on turbo outlet side broke, 3inch split. Repaired that prob but know I have a whistling from turbo ( I think ) when in higher revs.
I did find some oil residue in the pipe when I changed it
Any thoughts and advice greatly appreciated.
nick
Unread post by nick »
Some oil residue in the pipework from the turbo is perfectly normal.
If its whistling more than before the most likely explanation is a pipe may be split elsewhere, or another connection in the pipework perhaps came loose when you were repairing the original problem.
marsalek
x 19
Unread post by marsalek »
Hi bubber,
some oil is normal. A colleague of mine had the same hose split. Repaired it with an alligator tape, but it held no more than 2 months. The hose have been repaired more times, but finally a new one came inside :-(
Karel
bubber
Top banana,
Well, I think the lesson here is don't be a cheap skate and repair pipes :oops:
Possibly I mat have disturbed other pipes trying to get pipe back on.
Anyway, many thanks for your help and advice, will get new pipe :roll: .
Here's hoping it will be that simple a cure :?
