607 anti pollution warning
f00lzz
Unread post by f00lzz »
Hi Guys
Just bought a 607 2.2 HDI at auction 51 plate with 85k.. Display shows ''engine anti-pollution system defective'' I'm hoping this means the fluid/particulate service is due. If it is i'm alright cos the car was cheap as chips and it will be worth doing .... if it isn't and it is something more sinister I may put it back through the auction and let one of you guys have the hassle :D
Cheers
Ian
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
504GLD
Unread post by 504GLD »
I'm sure I will be corrected, but I'm led to belive its a fairly generic message to do with fuel/exhaust systems. I had the same message on my 1007 petrol when it had a problem with I think the air meter. The diag socket will tell all when connected up to a suitable computer. The car may go in to 'limp' home mode.
f00lzz
Hmm that costs money :( I was hoping it was the pollution 'service'.. judging by the mileage it is due for a cambelt change and possibly a Eoluy (or whatever it's called called) top up.. Cheers for replying
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
x 1056
Unread post by wheeler »
504GLD wrote:I'm sure I will be corrected, but I'm led to belive its a fairly generic message to do with fuel/exhaust systems. I had the same message on my 1007 petrol when it had a problem with I think the air meter. The diag socket will tell all when connected up to a suitable computer. The car may go in to 'limp' home mode.
Spot on, it basicaly means engine management light as just about every sensor failure would be classed as affecting the emissions.
f00lzz
Ok thanks for the input ..... i'll get it 'diagnosed'
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
x 94
Unread post by citronut »
if it is you atipolution system requires a service/top up, depends on the year of your car to weather you have Eoluy or the later type of fluid in the system, you must not use the wrong type,
also i belive the early cars have a tank float to indicate the amount of fluid left, and the later cars have an electronic counter,
the early car it is ok to just add fluid but if its the later car it has to have the system reset on the likes of a DIAG/LEXIA
my local pug dealer parts manager tells me they have found it it also best to replce a sensoid refill, other wise thew light can keep comming back on,
you are also ment to replace or clean the paticulate filter in the exhaust system
regards malcolm
f00lzz
All fixed.. It needed that Eoluy fluid replenishing... 5ltrs £90.0 plus £30.0 for diagnosing and re-setting.
Thanks for your input Guys.
Ian
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
