Xantia does not start pionting up hill
robmarshall
I have a 1999 Xantia 1.9td . When I park it for more than an hour facing up hill it wont start. If I park facing downhill it starts???? Any Clues ??
MikeT
- x 232
I'd think it's an air leak in your fuel line. Diesels won't run with a lot of air in the fuel. As gravity pulls the fuel back towards the tank (on uphill parking) air is being sucked in somewhere.
Does priming the fuel bulb make any difference? If you have a clear fuel line from the fuel filter to around the back of the pump, look for air bubbles as you're priming the bulb. Chances are you'll also see bubbles when the engine is running.
- x 1240
deian
robmarshall
Deffo air... Went to locate the priming bulb and it was not there.... Just a joint in the fuel line where it used to be... Ended up bleeding from an injector and it seems better. I will try when it is colder as it seems to start better when warm anyway. Also the fuel line is black so cant see the fuel or possible air in the line. I will post an update soon.
You gotta love Citroens dont you ..
Xaccers
- x 188
check the state of the leak off pipes between the injectors, if they are hard, then it'll be an idea to replace them.
When they get hard they crack and can let in air.
For a clear fuel pipe between the filter and the pump, I got some fish tank air pipe that did the trick beautifully.
DIY sphere tool
DIY sphere tool
