Ive tried a couple of codes from a decoder i downloaded but i can't get it working. I must be doing something wrong or using the wrong decoder, the hour wait to unlock is starting to get annoying! The radio was working prior to disconnecting the battery.
The serial number is bp2775v9721760
There are a couple of other codes 96 133 457 80 & 7642775394.
Can anybody help?
Blaupunkt ph1/c radio code.
97 Xantia 1.9 td lx with a/c (Daily, 172K, FOR SALE)
98 Xantia Hdi Lx with a/c (105k)
97 Renault Extra (c1j turbo 230+hp, 12.88@106)
91 Renault 5 Gt turbo (68k minter)
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4922
Part of your answer is here in Useful Links.
How are you entering the code?
There is a sequence to it but I forget what it is at the moment, I think that you enter the first digit by pressing the "1" key the required number of times, i.e. 5 times to enter a "5", then the same with the "2" button for the second digit and so on, after the last digit IIRC you press and hold "6" for thirty seconds.
Someone correct me if I am wrong, it's a long time since I last had to do it.
- x 54
Thats it Steve, only when the code has been typed in, a quick tap of '6' lets you in.myglaren wrote: There is a sequence to it but I forget what it is at the moment, I think that you enter the first digit by pressing the "1" key the required number of times, i.e. 5 times to enter a "5", then the same with the "2" button for the second digit and so on, after the last digit IIRC you press and hold "6" for thirty seconds.
Kev
'19 C4 Cactus 130 Flair
