Hi all,
I have a xsara est 2.0 HDI '99' V plate.. Wheres the bloody sump plug?!?!?!?! i think i have found it but theres seems to be 2, one above the other and guess what, i cant get the bottom one undone. Am i trying on the right nut??? its 21mm external with a 8mm hex internal..
cheers in advance
Sump plug
AndersDK
If your Xsara has got Aircondition, the sump would seem to have 2 plugs one above the other.
Should be found on the rear of sump facing towards pedal box.
Its always the lower one to drain as most oil as possible.
Presumeably the upper one is for optional fitting some kind of a sensor.
Anders (DK) - '90 BX16Image
red_dwarfers
- x 58
What Anders said, I imagine that if this extra plug is for some kind of sensor, it would be the oil temp?AndersDK wrote:If your Xsara has got Aircondition, the sump would seem to have 2 plugs one above the other.
I would use a ring spanner with a bit of metal pipe on the end for a bit of leverage, should do the trick
Kev
'19 C4 Cactus 130 Flair
- x 94
i took a sump plug out a couple months ago, felt normal on removal, tried refitting it and it just went round and round, it didn't even squash the new copper washer, ended up removeing the sump had an enginer cut a larger thread, to suit a dersh sump plug, that FFFFFFIXED the little BBBBBBBB a leson,
that now must be one of the fastest 2CV supm plugs on the planet
regards malcolm
regards malcolm
reblack68
That happened to the alloy sump on my TD before I got it. It was tapped in situ to receive a Mini sump plugcitronut wrote:i took a sump plug out a couple months ago, felt normal on removal, tried refitting it and it just went round and round, it didn't even squash the new copper washer, ended up removeing the sump had an enginer cut a larger thread, to suit a dersh sump plug, that FFFFFFIXED the little BBBBBBBB a leson,
regards malcolm
Richard
Care of a 1994 205 D.
- x 94
tgrfc
