Hi All,
found label on door pillar (just bought for wife) and says 2.4bar which equates to 35lb all round, is this a bit high??
funny how some misinterpret as the car had 24lbs all round!
Advice appreciated
Kevin
Tyre Pressures 206 1.9 d
- x 8450
What? You've bought your wife a door pillar Kevin
No, 35lb sounds about par to me. Modern cars to run with seemingly very high pressures compared to the oldies as it helps economy (lower rolling resistance) and there's a lot of weight to support.
The label usually gives two sets of pressures; one for normal running and one for when you have the car heavily loaded.
amjake
Citroenmad
- x 110
We have a 2.0HDi 206 which also says 35PSi all round. I found that a bit high so i set them to about 33/34 front and 30/31 back.
I always find having a difference between front and rear pressures makes a car feel more stable and gives more grip, so i never go with an 'all round' pressure.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
