Xantia dashbulb replacement and heater control
vince
x 13
Unread post by vince »
Hi gang,
Can you replace dashbulbs from under the drivers footwell? If not then do you need to remove the steering wheel to get the dash clocks out?
Also my heater control (ie hot or cold) slider isnt working properly...is it easier to replace the panel from a scrappers?
95 Xantia by the way :P
Vince
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
You can't gain access to the dashbulbs on a Xantia from under the footwell, you have to pull the panel out of the dash which on a S1 also involves removing the steering wheel, TBH its not that much extra work.
I take it that as your Xantia is a 95 its not fitted with A/C? If the heater slider isn't working its more than likely due to a cable fault such as a missing clip, remove the radio and look down onto the heater panel to see whats happening when you move the slider. To look at the other end of the cable you might be able to view it removing the glovebox (don't forget there's two screws in each corner under the felt).
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
vince
x 13
Thanks Richard i will have to have a look..doesnt sound too bad then :)
