Hope someone can help.....here goes!
I have a 406 2L HDi, 2001 model, and while it was up on the ramp getting an oil change I noticed the rear tyres were bald on the inside. They have only been on for six months or so, and haven't been on the front. I was told the axle on my car is not adjustable, as I was gonna get it 4way aligned. Looking at the back of the car, the wheels look like /--\ , though not as bad as that!
Has anyone any ideas which bushes if any need replacing? I have trawled through these forums and only found one reply applicacable, and I think it said another axle is required, but can't remember where!
Thanks in advance,
Gaz
406 rear axle problem
AndersDK
Hi Gaz -
Your 406 has a quite complicated rear axle setup. Far from the usual PSA setup found on earlier models.
There is a tranverse lower arm in which the coil spring is seated.
This lower arm is fixed on the chahsis in an inner bushing and an outer bushing in the wheel hub.
Then you have an upper control arm to keep the wheel vertical and a longitudinal control arm to control the wheels heading.
Initially I'd suspect the 2 lower bushes on the large transverse arm as they carry all the side forces involved on the rear axle. They should be checked like you would check standard front triangle arms seated in rubber bushings.
No idea what price level we talk here for any repair jobs.
But from the schematic it does not look like anything can be adjusted by shims or such, meaning its a straight forward replacement of parts.
Despite the rather complicated setup, it looks very simple to dismantle and replace parts.
- Except you will have to cater for the coil springs constant pressure
Note that you may need to replace other bushes as well in the smaller control arms.
Better check the complete setup while you are there.
For reference here is my local (DK) dealer approx pricetags (exvat) on the 2 bushings suspected :
5131.80 bushing (inner) approx £12
3640.41 bushing (outer) approx £17
Anders (DK) - '90 BX16Image
gaz4053
AndersDK
Ok Gaz -
Just checked with peugeot.servicebox.
The 2 bushings in question are the same all models.
Cant see any differences on the setup sedan/estate.
Might be only the coil spring and damper specs that calls out for a different parts list with schematic.
Godd luck with your 406.
gaz4053
- x 94
AndersDK
- x 94
yes Anders i now of this version of 406, and also have fitted one of those bushes for a customer last year, if this is the type Gaz has yes it is viable to fix, but it would be very unusual for this type to give the problem as on this car
i have also seen toursion bar rear axles on 406 saloons
regards malcolm
regards malcolm
AndersDK
I have no other technical sources than your workshop experiences Malcolm - and the listings found on Peugeot Servicebox.
Are you saying that it could be market specific which type rear axle setup is fitted to the 406 range ?
- as there are no other rear axle types indicated for 406 or 406restyle according to servicebox, no matter which 406model is chosen.
The 405/restyle is however the wellknown earlier torsion bar setup for all versions (except the hydraulic rear axle).
- x 94
AndersDK
gaz4053
Thanks both for helping out, the schematic that you have posted certaintly looks like it, but will check when I get it on the ramp sometime this week. Am I right in thinking that this set-up is non-adjustable? I will take a picture and upload it.
Again, thanks for the help both, it's much appreciated.
Gaz
Gaz
- x 94
