Woman in Need of Help!
lovely_linday
Unread post by lovely_linday »
Hi
I have a Renault Clio 04 plate. A few weeks ago my interior light started coming on on its own and then recently the 'door open' sign started coming on without a door being open.
Now both my key fobs have stopped working.
I took it to a Renault dealer who have advised that it is going to cost £400 to fix and take 2 days. :evil: Any idea what they are going to do?
I would appreciate any advice.
Linda :D
Homer
x 16
Unread post by Homer »
Probably replace the door switches. :roll:
My guess would be, one of the door switches (which IIRC are on the opposite end to where the hinges are, and easily get snagged and pulled out), has failed/dropped out. This is telling the system the door is open so it is refusing to unlock/lock.
How long did the dealer have it to come up with this (2day £400) diagnosis?
lovely_linday
tried all four switches, all seem to work ok? any other ideas, thanks :)
x 5679
Broken wires in the loom where the door hinges.
While a DIY fix would be to repair the individual broken wires by splicing in new pieces it wouldn't be acceptable for a professional repair, they will be charging for stripping out the loom and replacing it with a new one.
Could take a while but the price does seem to be on the high side.
It may be worth getting a quote from a reputable auto-electrician, preferably one who is known to you or to your friends. If the dealer bodges the fix you have some come-back, an independent, not so much.
