Original Citroen C5 radios. How much?
Marky P
C5 (03) CD player is knackered. How much would a direct OEM replacement cost? They rarely turn up on Ebay and when they do they need coding to the cars, which is another cost. Tried installing a JVC radio and buggered up the car (it won't start) so I've given up on that.
Marky P
- x 5674
You should be able to replace the original (Clarion?) unit with an after market one. Sony have a reputation as being particularly compatible but I couldn't vouch for that as I still have the original.
You can even use the controls on the stalk with a suitable adapter lead but AFAIK the display won't work.
Word is that a dealer replacement of the original unit is insanely priced. I'm sure I have heard £600 mentioned
reblack68
- x 1056
Re: Original Citroen C5 radios. How much?
Any aftermarket radio will fit into a C5 without any problems whatsoever as long as its wired up as per the radios instructions, for the radio to cause the car not to start you must have pluged the radio into the VAN network wires.Marky P wrote:C5 (03) CD player is knackered. How much would a direct OEM replacement cost? They rarely turn up on Ebay and when they do they need coding to the cars, which is another cost. Tried installing a JVC radio and buggered up the car (it won't start) so I've given up on that.
den169
I have a sony mp40 in my 03 c5 estate also works with the steering control too,Had to buy an adaptor for the facia off ebay and an adaptor to make the controls on the steering column work with it.Plays Mp3s so one disc is like having a 6 disc changer in.I also have a 6 disc sony mp3 changer in the back too.So 7 discs full of mp3s plays for days.
Marky P
den169
Marky P
