Coolant level 1.9TD
vince
x 13
Coolant level 1.9TD
Unread post by vince »
On the premise that there is no such thing as a silly question.... :P
My coolant is black with no visible max / min marks on it. How do you check the level is correct?
x 8391
Hi Vince,
Good Christmas?
You'll see a tube in the filler neck. Correct level, when cold, is at the bottom of this tube. If filled any higher, it'll just blow out what it does not want.
Water consumption should be practically zero.
x 94
Unread post by citronut »
just to add there is a slot in said tube and the coolant should be at the bottom of the slot when engine is cold
regards malcolm
vince
x 13
Thanks Malcolm, yes Christmas was good. Just want a good start to the new year by getting back into a job :wink:
I dont seem to be losing coolant and the temp is spot on. Im going to get the coolant changed when im back earning again, just like to know what im checking :)
You got to ride in Dickie's DS didnt you......lucky boy :) Its one of my life's small wishes too....at a show next year no doubt :wink:
