Initially, there was an intermittent fault (i.e. dash went black then appeared again – often whilst driving). Now it’s gone for good!!
Lights, Indicators etc all work fine.
All fuses are OK – but now my Radio won’t work as it died when I removed fuse to check it and I can’t see the dashboard numbers to re-enter code!!!
QUESTION 1:
Is this a common fault and is there a simple 'fix' that anyone knows about?
QUESTION 2:
Does this sound like the Dashboard Cluster, Component (e.g. Relay) or some kind of 'Mother-board' failure?
QUESTION 3:
If I need to replace the whole cluster – as a unit – How do I get the old one out? There doesn’t seem to be any obvious way of getting the old one out? Also, where can I get one from that I can be sure will work 9and how much do they cost - approx.)?
QUESTION 4:
If I get it out, is it simple to re-fit (i.e. is it just a push-fit connector to re-attach electrics etc?
QUESTION 5:
Do I need to remove the whole dash-board? If so, how?
QUESTION 6:
Is the above 'do-able' by a layman (i.e. me) or will I need to get it done through a Main Dealer or similar?
I know I've asked loads of questions but I'm completely stuffed at the moment - especially at this time of year! Your help is much appreciated.
