pollen filter
mordacai1
pollen filter
my wife han 8 valve .1999 s reg megane 1.6e with a/c.The windscreen is steaming up.decided to check the pollen filter as per haynes instructions.unclipped the scuttle panel but no filter.any ideas please
- x 5679
Could just be a bit of condensation due to water left in the aircon system.
I believe the trick is to kill the aircon before ending your journey as if the condenser is still cold it will remain so and condensation ice or will form or linger, when starting up this will be deposited on the screen (condensation, not chunks of ice
Mine does just this as I always leave the aircon on automatic. It only mists the screen over for a few seconds. By the time I have finished messing around and am ready to drive off it has cleared.
Nicky
had the same on my laguna. 2 days ago replaced pollen fillter on warenty. seemd a bit better, the old one was wet and old. i belive some remove the damp filters and leve them out rather than replace. i am geting some mur anti fog/mist window stuff of ebay recomended by a friend. will let you all no if it helps.
