citeroen beling 1.9d van wont start
hi guys,i have a problem with my van not starting i have had new battery new starter new plugs and new filter it only seems to do it every so often and once its started it fine all day but it always seems to be on the day i really need it any ideas?ive had all wiring and that checked
- CitroJim
- x 6204
- Contact:
An XUD need three things to start: Preheating (always - hot or cold), fuel and compression. Loose any of the three and no start.
Peter, your smoke test is good. If it will not start and emits No SMOKE at all, this indicates no fuel is reaching the injectors. If it smokes white/grey smoke whilst not starting, this indicates that unburned fuel is going straight out of the exhaust, signifying either a loss of pre-heating (glowplugs not working) or a loss of compression.
Some XUDs can suffer from the valve clearances closing up to the point that when cold, the valves are just held off their seats, resulting in a dramatic compression loss. A quirk of the XUD is the valve clearances are tightest when they are stone-cold and it takes a mere whiff of heat to expand things sufficiently to allow the valves to close and the engine to start.
My bet here is that the glowplug controller is intermittently duff and now always engergising the glowplugs. Temporarily wire a small bulb on to one glowplug, visible from the dash, to see if this is the cause.
- CitroJim
- x 6204
- Contact:
No, actually quite simple. Look at your injectors and you'll see little black rubber pipes daisy-chained between them and going off to the fuel return line on the pump. The last injector has a rubber blanking cap where another leakoff pipe would go if there were more injectors.berlingo1 wrote:sounds like a job for a mechanic
Pop into your local factors and pick up a leakoff pipe kit. This'll have about a yard of pipe and a new blanking cap.
Replace like-for-like and job done!
These pipes run hot, go brittle, leak and let air into the fuel return line which in turn empties the pump of diesel over time.
