service.citroen indicate that the 1.9TD and 2.1TD are identical in regard to auxillary belts and tensioners. They do look the same.
Before I go spending my pennies, can anyone please confirm the GSF part numbers are correct for what I'm after please:
N13179B RIBBED BELT TENSIONER
13354D ALTERNATOR BELT-6PK 1690
For the belt, service.citroen quote either a 1725 or 1735 depending on the A/C compressor fitted and yet the GSF one is a 1690. Is that OK?
Might explain why they're such a fight to get on, needing the spring tensioner to be fully retracted.
Many thanks
