radio code
rummins 123
radio code
Unread post by rummins 123 »
hi can anyone please help ? i have in my xantia a blaupunkt radio that needs a code, i have allready payed on a car radio decoding site and the code they gave me was -110 which doesnt work it puts the radio back to ---- .
my radio details are as follows
BP2492T2877106
7 642 492 394
PH1/D
ANY HELP IN THE CODE &INSTALLING PLEASE HELP !!!!!
exect
Unread post by exect »
Are you sure you installed the code correctly, as they are 4 figure codes and yor first figure is a blank.
Regards
Exect
bonnyman750
x 3
Unread post by bonnyman750 »
Hi there, all three Blaupunkt calculators I have return the following two codes :-
8503 and 0503
HTH
Glyn
bonnyman750
x 3
Hi again,
sorry, forgot to mention, each dash represents a code number. So if code is correct, say 8503, press button 1 - 8 times so the figure 8 appears instead of the first dash, 5 times for button 2 etc until 8503 shows on the screen, then press either button 6 or 'BAND' button and radio should work. If these codes don't work, which is a possibility as some of the decoding software available can be unreliable, then please let us know as someone else on the forum may be able to give you another code to try...
HTH
Glyn
rummins 123
HI THANKS FOR REPLY, I WAS GIVEN THE CODE -110 I THOUGHT IT WAS FUNNY TO AS IT HASNT GOT A FIRST DIGIT SO IT DOESNT WORK.
I HAVE ALSO TRIED 8503 &0503 WITH THE SAME RESULT IT DOESNT WORK I GOT 1 OF THOSE OBD DISKS OFF EBAY WHICH GAVE ME THESE CODES SO IM AT A LOSS THATS WHY IM ASKING FOR HELP.
bonnyman750
x 3
Hi again,
tried another calculator and got the following:-
6110
0110
0170
Good luck!!
Glyn
rummins 123
cheers glyn i shall try those and keep posted thanks
rummins 123
THANKS GUYS FOR THE HELP 6110 THATS THE PUPPY CHEERS
