ABS ECU
mcgregor
ABS ECU
Unread post by mcgregor »
Hi
Can anyone tell me where the ABS ECU is located in a 2001 Xantia HDI 110 please. I have an ABS alarm light up and I suspect it is one wheel sensor and need to check out the resistance but I have no idea where the ECU is located. Any help gratefully accepted.
Cheers
Dave
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Dave, are you able to get any more specific information from the diagnostic socket under the dash? I've never had an ABS fault, so I don't know how specific the logging is.
From memory, my ABS controller has a multipin plug on it, so the ECU may be self-contained.
Regards, Adam.
mcgregor
Adam
That is exactly what I am looking for (the ABS ECU multiplug) Where is it? Is it under the bonnet or under the dash?
KP
x 27
Unread post by KP »
It on the passenger side of the engine bay usually just in front of the LHM resevior.
Should have a good few pipes into it and then the multiplug on side or top depending on varient.
mcgregor
Brilliant. Thanks very much.
Dave
mcgregor
I found a photo of the ABS unit plug in a previous thread so I tested the plug last night and got results of 3 out of the 4 showing 1070 ohms while the LHR (is that N/S?) showed 1028 ohms. Is a 42 ohm loss enough to be giving the problems with the ABS unit? Sometimes it resets and the light goes out when I first move off but then it returns after a minute or two.
As before any info gratefully recieved before I go out and spend £60+ on a new rear sensor.
Cheers
Dave
x 8391
mcgregor wrote:Is a 42 ohm loss enough to be giving the problems with the ABS unit?
In my experience Dave, yes :cry: The ABS ECU is very sensitive to even small changes in sensor resistance. 42 ohms is enough.
If you could get your car on a Lexia, you'll find the iffy sensor is reported as being out of specification and every now and again it will light the ABS warning lamp.
Shame it's a rear sensor as they're not as easy as front ones but on the bright side, at least they're a little cheaper :)
It'll be worth just checking the sensor connector for dirt and good contact before ordering a new one though.
Sorry to be the bearer of bad news Dave :(
mcgregor
Thanks Jim you really just said what I was thinking. Still not sure about LHR though. Any thoughts?
x 8391
LHR is indeed the N/S Dave. L and R is from the viewpoint of sitting in the drivers seat.
mcgregor
I thought it was but needed confirmation. Thanks very much Jim.
Cheers
Dave
KP
x 27
Unread post by KP »
I have a full rear swing arm if you wanted to make the job a bit easier comes with hub as well?
Depends where you are though as they are very heavy....
mcgregor
Thanks for that but I live in far NE Scotland, but I reckon a sensor change will not tax my abilities too much.
Cheers
Dave
