picasso heater
meexi
picasso heater
Unread post by meexi »
the other halfs picasso heater has stopped working checked fuses my picasso is an sx but has exclusive digital aircon which operates as normal.
do you think its the blower motor or the ignition (diesel) switch?
2004 C3 XTR HDI 16V 92bhp
2004 Xsara Picasso Exclusive HDI 16V 110bhp
1989 Peugeot J5 Hymer B694 2.5td intercooled 8v 96bhp
x 1056
Unread post by wheeler »
At the top of the interior fusebox there is a single pin black plug with one wire going to it (i think the wire is pink from memory) if there is no 12v feed at this wire with the engine running then its most likely the ignition switch at fault. the switch is available seperatley from citroen.
meexi
thanks for that wheeler i have not checked it yet can i bypass the switch?
meexi
you were right wheeler seems to be loose at the ignition end i will order a new one monday.
one more thing i noticed on the service citroen site that there is a rapid info 9 no 16 does any body know what that is about?
