Odd fan behaviour
reblack68
Odd fan behaviour
Unread post by reblack68 »
In this cold weather I've been using the heater fan on full power and I've noticed something a little odd.
When I floor the throttle the fan speed picks up, then drops when I release the throttle. The obvious answer is that it's the alternator kicking in but this happens long before the revs pick up (it's a 1.9TD, it takes a while :lol: ).
My feeling is that something is drawing a lot of current on low throttle, but what?
Does anybody have any theories?
Richard
Care of a 1994 205 D.
x 1240
Unread post by Peter.N. »
Mmm, sounds as though the pressure on the throttle is disturbing a faulty connection in the supply to the heater. You can check if something is loading the battery by connecting a voltmeter across it and checking when you depress the throttle.
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
Is this happening the first time you floor the throttle after starting? If so then what's happening is that by applying maximum drive it causes the glow plugs to turn off, hence removing a significant load on the electric system = faster fan speed.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 94
Unread post by citronut »
or the sudden exceleration the heater plug conector is moveing giveing a beter conection
regards malcolm
reblack68
DickieG wrote:Is this happening the first time you floor the throttle after starting? If so then what's happening is that by applying maximum drive it causes the glow plugs to turn off, hence removing a significant load on the electric system = faster fan speed.
That'll be it. It's not just the first time, but it's in the first few minutes.
Richard
