MOT passed OK but recommendation - Front flexible brake hoses!
Is depressurisation required to do this job as unless you apply brakes, surely there's no pressure?
Having had the spheres changed at Westroen, I have not had to depressurise the system. Having only 6 spheres, which doesn't sink much when engine off, do I follow the Haynes manual for 'earlier' or 'later' models?
Malcolm
'98 Xantia 1.9TD Est - Front flexible brake hoses
Malcolm
Malcolm
'98 Xantia Estate LX - RIP 13/08/16
'08 Renault Trafic 115dci
Malcolm
I've just read the Sticky so believe that's answered one question - in order to fully depressure an Anti-sink car you need to select LOW with the engine running, and then leave it running for a minute or so before switching off and opening the bleed screw.
The rear sphere is the Anti-sink is it not?
Still interested in why depressurising req'd.
Malc
Malc
Malcolm
- x 5674
It is always wise to depressurise the system while working on it as there is a lot of pressure there and it can be quite dangerous.
Citroen invariably stress this and while much of it is covering their collective derrieres there is a lot of common sense in it too.
While the brakes should not be under pressure anyway with the brake valve closed, why take a chance?
Depressurising and repressurising are so simple, along with bleeding afterward that part is probably going to be the least of your worries.
Corroded unions are a far bigger headache.
Xaccers
- x 188
Get the car on high,
put axle stands under the jacking points at the front,
slacken the wheel nuts,
set it on low,
watch the rear sink and the nose lift up off the ground,
let it run for a bit,
stop engine and then undo the 13mm bolt on the pressure regulator by the accumulator, but only enough to make it hiss until the pressure is released.
Pinch the bolt back up.
Now you should have plenty of access with the wheels off to get to the brake pipes.
set it on low,
DIY sphere tool
DIY sphere tool
Malcolm
- x 8391
Not such a big worry on a Xantiamyglaren wrote: Corroded unions are a far bigger headache.
It helps too that that there is usually enough oil from the engine to have kept most corrosion at bay from the end of the flexi where it joins the rigid supply pipe.
As a result, the flexis are not too big a problem to replace. The biggest headache is the constant dripping of slippery LHM from rigid supply pipe to the flexi. It gets all over your spanner and hands
- x 94
Malcolm
