intermediate drive shaft bearing
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
hi all can anyone help?
I have done driveshaft removal many times without an issue, but right now this one is being a pig
I have hammered, leavered and used heat on the aluminium casing but it wount budge :(
any thoughts?
John
jgra1
(Donor 2021)
x 36
please... :? :shock: :evil: :roll: 8)
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
Without wishing to state the obvious I take it you have undone the two bearing retaining 'hooked' bolts?
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
jgra1
(Donor 2021)
x 36
:D
yep
x 94
Unread post by citronut »
again the obvious is the outer end out of the hub, i usualy use an old large srewdriver with out its handle to drift these out against the colar at the diff side of the mountting, dont usualy have a prob
regards malcolm
handyman
Unread post by handyman »
Hello John, sometimes you need to heat soak the alloy casting to get the interference fit sealant used on the bearing outer race to release the bearing. I do have a small lipped brass drift that can just about get on to the outer bearing race and usually find once the tension is broken, the bearing comes out easily.
Failing that, a shock loading (Big hammer!) on the drive shaft usually dislodges them. Never seems to wreck the bearing. :shock: Have you got a dead blow hammer?
Handyman
jgra1
(Donor 2021)
x 36
hi all am I going to try and take the housing itself off, have tried leavering and a 2kg mallet..
http://406coupesev6.blogspot.com/ shows a few pics from day one (late start wednesday)
back at the car now, will keep you posted, thanks for help
John
x 8406
Last time I had this obstacle John, it took a big cold chisel (shaped and blunted to fit snugly against the bearing collar on the driveshaft) and a 4lb club hammer...
jgra1
(Donor 2021)
x 36
tried it Jim :) access is tricky as this V6 has a handful of exhausts underneath :)
4 16mm bolts and the housing now appears loose ,,,
jgra1
(Donor 2021)
x 36
well well...
see my 406 blog, (thursday) for more..
the intermediate bearing was ok, no problems.. the issue is the driveshaft is stuck fast into gearbox :evil:
x 94
the only time i have seen the shaft reluctant to part company with the gear box, is when i forgot to knock it clear before undoing the clutch houseing bolts, this causes the shaft to become stuck as the box moves slightly out of square to the engine
regards malcolm
jgra1
(Donor 2021)
x 36
hi Malcolm, hmm.. even with the box out on the floor and all pressure off the shaft, it's not budging. guess I will have to leave it as it is, and put the gearbox and driveshaft onto the new engine.
If the tri axle ends seem all to be ok and not falling apart, can I just mesh the two ends together, add grease and not worry about it ?
John
jgra1
(Donor 2021)
x 36
well 90 kilo's of autobox was thrown into my dear xantia and duly taken to a gearbox specialist and driveshaft is now free to go it's own way :)
a big hammer seemed to be enough :( i tried many things including hanging the box off a crane (by driveshaft) and adding to it's weight with my hammer to no avail
6 hours to remove a few splines... gutted :(
many times I have done this, a few mins max,
...but this one does not have the rubber outer seal which I condemed in the past as being pointless.......... the one tthat stops rust?
x 94
i know this one has been a little s**t, but when removeing gear box with 0/S shaft still atatched to int mountting and rear of engine, you will bend the inner half of the drive shaft
regards malcolm
jgra1
(Donor 2021)
x 36
its been a nightmare Malcolm
to be honest, changing the driveshaft in the near future will be a walk in the park now it has finally come out.. I am more concerned for the diff and the gearbox...
Will know soon enough what was damaged :(
