306 coil pack failing?
pug_owner2002
x 3
Unread post by pug_owner2002 »
Hello All,
I've not had any reason to post lately (however I do enjoy reading other posts, especially the blogs!) as the 306 has been running as sweet as a nut...until now.
when accelerating hard a slight missfire can be felt, this has started to manifest as a severe missfire if the car has been left stood over the weekend (when it's cold and damp) I'm guessing that the worse one is caused by the damp.
I have a feeling that the coil pack could be on it's way out, the car (2001, 306 1.4 LX) has done just over 100K now.
Is there a simple way to test the coil pack as substituting it is an expensive way to find out that it might not be the problem.
Thanks.
R Reg Phase 2 306 DTurbo (Blaze Yellow) (Sold)
X Reg Phase 3 306 1.4 LX (Sold)
03 Renault Scenic Dynamique +
03 Seat Leon 1.9 TDi
52 Nissan Almera 1.8 sport+
x 94
Unread post by citronut »
that depends on were you are as i have a second hand one to use for test purposes if you are close to east sussex,
or you could buy 4 flasher caps which are yellow plug caps with a spark gap inside, so you fit all 4 then fit the coil pack back in place and start the engine,
these are noot a lot of money from a good motor factors
regards malcolm
