Hi. I had to replace the leak off pipe from injector 2 to 3 on my 1.9 td xantia. I didnt have any injector pipe available, so have cut off some of the LHM resivour overflow pipe and used that to get me out of a hole. This has worked and is holding. The question is will this be ok for a permanant repair and what does the leak off pipe do. I assume it carries unused diesel back into the system?
thanks.
xantia injector
- x 8391
- x 1240
